citect & siemens step7
esmail
Mar 2004
tehran
hello!
I want to have a communication between citect & siemens step7-300 in simulation mode how can I do it?
You can NOT connect to the PLC-SIM simulator for S7 programs.
The only HMI package that can do that is Protool.
A sneaky way to do it would be to let Protool Pro connect to PLC-SIM and then forward the connection to Citect (Protool Pro can act as OPC server). But that requires you to have Protool Pro, which you probably haven't.
Get a spare S7-300 CPU and use that as your simulator.
You do not need to have a real plc to test your Citect project.
The first thing what you need to do is go to Citect Explorer / Communications and run the Express I/O device setup. At one point Citect wil ask you what kind of I/O-device you have. You have 3 options. External I/O device (a real plc), memory I/O device and disk I/O device. Select disk I/O device. Now you are able to simulate a plc. Your simulated data is stored on your hard-disk. A memory I/O device uses the same concept but the data is stored in the RAM-memory, so you will lose all simulated data after you have shut down your computer.
The second thing what you need to do is create simulated I/O in your Citect project. There a basicly two kinds of I/O; digital and analog.
Digital I/O
Example; in your project you already have a graphical symbol defined for a tag with the name "motor". The ON-symbol is a green motor and the OFF-symbol is a blue motor.
Now you must simulate the two possible states of this motor; ON and OFF. Push the 'symbol set'-toolbutton. There is a black and a red circel as ON and OFF symbol. This is just fine for testing. In the box 'Appearance' you need to insert the tag 'motor' (On symbol when). Then you go to the box 'Input' and type "toggle(motor)". Toggle() is a function that will change the state (ON or OFF) of your tag everytime that you activate this function. One time it works like a SET-function, the next time it will work like a RESET-function. The toggle() is activated on the UP-command. This means that you need to click on the graphical symbol with your mouse-cursor. Only when you lift your finger up, the toggle() will be activated. Now your simulated I/O works like a light-switch. If you want it to work like a push-button you also need to make a toggle() as a DOWN-command. Go to Run-time and you will see...
Analog I/O
Example: you have a tag named 'level' between 0 and 1200 and you already have a graphical symbol for this tag.
To simulate analog I/O, I use the 'button'-toolbutton. In the box 'appearance' you can type the text "level". Goto the box 'Input'. On the left there a two possibilities; Touch and Keyboard Commands. Choose 'Keyboard commands'. On the leftside there is the 'Key sequence'. Here you type the text "####enter". In the middel you will see a white box now renamed into "'####enter' command". Here you must type the text "level=Arg1;".
If you also want to see the value of your simulated analog I/O you need to use the number-toolbutton. The numeric expression must be the tag 'level'.
In Run-time you must position your cursor over the simulated I/O-button. You can type a 4-digit number. The tag will only change after you push enter on your keyboard.
May the force be with you.
I have a simatic S7-200 smart PLC with SR20 CPU and ethernet port. I would like to interface it with my Vijeo citect 7.4. it would be really...
1,182
I need to know the steps to communicate Citect 2016 with Siemens S7 1500 using S7TCP driver. Thanks
27
17,930
hi how can i Communication between Siemens S7-300 and Vijeo Citect 7.2 with Ethernet tcp/ip ? please help me!🤞🏻🤞🏻
1,815
Hi, I have a plant with 400 CPU and a HMI system from Scada (7.20). I want to let the 400 cpu sync against Citect. Citect already time sync...
1,819
I'm wondering if anyone has any insight into Siemens communications and may be able to help me with a communications problem I'm having? I have a...
4,197
