Citect Window position control problem
IainH
Jul 2008
Sussex
44
I am attempting to set up an HMI using Citect V6 on a PC with 2 monitors. I am using a primary citect project to display the main system control pages on monitor 1 and an included project with pages displayed on monitor 2.
My main project starts with the display of a splash screen (on monitor 1) and after initialisation I create a new window using
WinNewAt("UserID", 0, 0, 16);
which subsequently uses
PageDisplay("Other_Page");
as required.
The monitor 2 window is also set up after initialisation using
WinNewAt("Second_Monitor", 0, 0, 16);
WinPos(1024, 0);
I need to use WinPos() as WinNewAt() will not position the window where I want it? :whistle:
However, my main problem is, when I execute a Login() instruction in the main project, the window on the 2nd monitor is repositioned on the first (behind the window displayed there). :mad:
Is there any way to stop this happening other than to continually check the position of the 2nd window monitor page (using the Page Event - "While page shown") and reposition it when it moves?
Iain
Are you using the Citect supplied multi monitor cicode
I have had to modify some functions to suit my application
Here are the statments that I call during start up to display on each monitor
How do you have your display set up ie Span (eg 2048 x 768)?
PageDisplay("Overview"); !First screen
WinNewAt("CMO0000",1024,1,0) !Second screen
Not sure what you mean by "Citect supplied multi monitor cicode", but if I try putting
[Multimonitors]
Monitors=2
in my citect.ini file, nothing I do makes any sense!
I am starting my project with a splash screen on monitor 1. This always has a Windows caption, so I then create a new captionless window in the initialisation routine and free the original(?):
WinNewAt("M_Splash", 0, 0, 16);
WinSelect(0);
SleepMS(500);
WinFree();
Then, after initialisation is complete,
WinNewAt("Second_Monitor", 1024, 0, 16);
I now have the two screns where I want them and keep the second one in position by adding
If PageInfo(14) <> "1024" Then
WinPos(1024, 0)
End
In the While page shown event of the page.
It's not pretty, but it works and allows me to report some progress!
Thanks,
Iain
Hello,
i am not shure witch version you are using but since you found the [Multimonitors] parameter i am guessing you are using 5.50 or higher.
The integrated multimonitor functions kellian mentiond are part of the CSV_Include project (where the xp style templates are located)
if you want the first window to be caption less you can change that in the computer setup wizzard. use the custom wizzard and turn off show title bar.
Now when you want to use the integrated multimonitor support you should use "CSV_MM_PageDisplay" and "CSV_MM_WinNewat" instead of the normal "PageDisplay" these functions should position your windows correctly. it takes some tweaking but should work. Those functions are originally designed to work with the xp templates but we can get them to work on normal pages as wel.
If you are using an older verion of citect let us know and we wil find another solution.
hope this gets you on the right track
regards
Marsupilami
If you can access the Citect Knowledgebase there are several articles on using Multi monitors
Q4688 being one of them
Yes Q4688 is a good place to start, i have attached it if you have not already seen it or do not have access to it.
I have a comparative program in M340 PLC in which when a condition is true a memory bit is set to high. I would like to Pop UP a new window every...
2,399
Hi group! Just getting started with the Citect product and going through a training manual. The step I'm working on explains the process to...
7,026
Hi, I'm using Citect7.20 and need to popup a modal window. By modal, I mean the user should not be able to click on parent window until he/she...
16,204
just a quick question... On my server PC i have a number of programs running at the same time, each displaying different plant information. my...
3,418
Is there any way in Citect to prevent windows being redrawn when a user logs in with a new priveledge level? I have a number of Citect windows...
2,130
