CLC and Wonderware
eber66
Jun 2008
Indianapolis
17
Hey I need some help here. I am trying to get my CLC communicating and I am having problems. We had a hard drive failure and I am switching to a new hard drive with a ghost of the previous installed. Everything came up except for the fact that my CLC is not communicating to my screens. I dont know if this is enough info for you but I have tried everything I know to get it working. It is a serial connection and I think I am just missing something small. Any ideas?
Did you look at any of the diagnostic menus on the clc dde server?
Do you have VisualMotion on the PC? Does it talk to the card?
Is you serial port still the same com port?
Yep everthing on the diagnostics menus looks good.
VisualMotion is on the PC but is not communicating either.
And the Serial Port is still the same Com port.
Sounds like the serial port setting of the DDE server do not match what the CLC is setup for.
Change the serial port settings until it talks with VisualMotion.
The bottom serial port setup for 9600, if you want to test it. The top port could have been set to 9.6, 19.2 or 38.4.
Hello, I would like to know when/why one would use the Clear Carry (CLC) instruction before performing arithmetic operations for a C200HX. The...
19
4,206
hi all i want to replace indramat clc-d02.2 instead of clc-d02.1 on drive dds02 1-a100-0 on a kba printing machin. can any one help me? thanks...
1,284
Has anyone got a copy of AB slc-100 programing software that they are willing to share. I believe it can be sent as an e-mail attachment. I tried...
2,615
I'm stuck in a loop and need some help. Just got a used machine in with a s7 PLC and indramat CLC d02.3 motion control. I am not familiar with...
2,601
Top of the mornin to ya, I recently backed up an Indramat CLC Motion Controller card that controls 6 drives in the loop. I used VisualMotion 7...
1,745
