bulletin blues
I was messing around with the FBC function in logix 5000 last night. I want to compare until I find a match and then continue on the array using ladder logic.
I figured I would just MOVE "0" to My_FBC_Control.IN(terupt) and let it continue comparing.
I got compile errors saying "incorrect data type."
The help file says you must CLEAR the ".IN" bit to continue the compare.
I tried setting MY_TAG as a boolean and setting it to zero and MOVING it into the My_FBC_Control.IN.
Still says I'm using the incorrect data type.
Heck, I even tried the CLR function since the helpful help file says I need to CLEAR the bit to continue.
Works O.K. if I just toggle the bit in the tag monitor. Confused about the setting it up in the ladder with the "incorrect data type error."
Ugh, I feel like an idiot.
I figure I'll get it figured out tonight (time permitting) but I'm looking for a hint, while I'm at home, trying not to think about work.
Thanx
Thanx
