CODESYS Gateway does not start, cannot scan CODESYS devices
AlfredoQuintero
Feb 2015
Yokohama
1,571
Hello:
I have a problem I had never seen before with CODESYS and it seems to have happened after I added some new installation to this Windows workstation.
As shown on the screenshot below, the CODESYS gateway does not start, and as a result it is not possible to scan CODESYS devices. Looked into CODESYS forums and there are a number of similar inquiries but no explanation on the resolution.
Would be very helpful if someone has found this issue and could share a solution.
In CODESYS Installer, Settings, change the default gateway to the version you want to use ( and back again). #random-troubleshooting-ideas
Once again, AustralIan, you have come to the rescue.
Your solution worked. Thanks so much.
paraffin power, thanks for your comments too.
hi, I am currently working on a project that requires access to the data inside plc using Codesys OPC server v2.3 and I want the data to be...
3,050
Hello, I would like to execute code saved in initialization FB on the first start of the PLC. It is basically something like OB100 in the Siemens...
99
Hi! What is the way to convert the code from the Codesys code to the Tia Portal? Regards, WK
119
Hello to all, can you please provide an example of obtaining a current working directory as a string in CodeSys? For example, during starting the...
237
Hello to all, I'm just starting with using CodeSys. Immediately, I have noticed that Codesys doesn't use data blocks like for example S7 does...
240
