CoDeSys log I/O value to Excel/textfile
You can use the file I/O library to write CSV files. Pretty straight forward.
If you're using a PLC like a WAGO 750-88x you've got about a meg to Play with. The 750-880 has an SD RAM slot so you can store up to 8G. Be warned, however, that if you're planning to do a lot of this, SD RAM has a limited number of writes, about 1M if I remember correctly.
If you're using the soft PLC the number of writes is not an issue.
Good Luck,
(8{)} :) .)
(Yosi)
Hi all, i tried to create a log file for a variable in my simulation program using Excel through DDE. can i make Codesys record the variables...
2,271
I'm using a pressure sensor that outputs 4-20mA related to a range from 0-6 bar. i want to connect this to my WAGO 750-485 module. It's the...
4,794
Hi everyone, I'm trying to go online with an IFM PLC over a serial connection, using CoDeSys. Things were working fine for a while; I managed to...
11,504
Hello, I would like to execute code saved in initialization FB on the first start of the PLC. It is basically something like OB100 in the Siemens...
101
Hi! What is the way to convert the code from the Codesys code to the Tia Portal? Regards, WK
120
