Cognex InSight 5000 AOIs
widelto
Jul 2005
Barranquilla, Colombia
3,392
Hi all :
Has anyone used AOIs designed by cognex to be used with Insight 5000 cameras.
Info on their web page is poor, i'd like to use them in my new project with two cameras.
I'm using RSlogix 5k, v20.
Any tip will be appreciated.
regards,
william
Hi all :
regards,
william
I wouldn´t suggest using their AOI´s based on what I have seen from their sample code. Their sample code is very poorly written (using a MOV 0 instead of a CLR instruction, wrongly branched ladder logic etc). The camera´s are relatively easy to use and usually Cognex are very helpful in terms of setting the cameras up and comunicating etc.
I suggest you contact Cognex directly because their website is terrible!
Have not used an AOI designed by Cognex, but have several communicating with CLX processors. What are you looking to get out of the camera? Angles, a go/no go, other critical data?
hello all, Im very new to cognex software, and I'm picking up a project where someone that is no longer with us left off... See the attached...
2,127
Gents, We have the following configuration: A Beckhoff PLC with EthercatMaster > EK1100 with a EL6652 EthernetIP Master. Plan is to...
398
Once in a while I am asked to look at some Cognex vision programming/cameras in our plant from 5 - 10 years ago. It seems every time I open up a...
1,755
Good Morning , I'm new to Cognex Insight Vision Suite Software. When I connect to my 3 cameras , I only have 1 with the Spreadsheet tab...
2,329
Good Morning , I tried to install Cognex Insight ViDi and suite on a Window’s 7 laptop , and it says it will only install on a Windows 10...
1,567
