Cognex Insight Camera straight to PLC using Modbus
TFBest86
Aug 2010
San Antonio
I recenlty came across a problem in that I have two brand new 64 bit servers running Server 2008, the problem is that the Cognex Insight OPC server is not compatable with 64bit systems or Server 2008. I want to cut out the Cognex OPC server completely as I have always had problems with it. So what I would like to do is pull the information straight from the camera to the PLC using Modbus. The cognex camera is 5400, the PLC is a Modicon TSX Premium Telemecanique. I might have left out some important points, but I am very new to PLCs and this form of data communication. Any help would be great.
TFBest
I cannot say anything about Modicon PLC but I can assure you that Modbus TCP/IP does work with Cognex In-Sight and other PLCs. The mapping of Cognex spreadsheet cells to Modbus internal memory addresses is described in In-Sight Explorer Help file.
As a matter of fact, it is a bit strange that there was an OPC server in between.
Now, I apologize if this is a little off topic, but it is connected to a plc that should send a trigger to the Cognex 5400C camera. Since they're...
4,678
Hi guys, As a topic title says.. If someone would be so kind to point me in a direction.. ATM I am mostly concerned about camera value output...
3,205
Gents, We have the following configuration: A Beckhoff PLC with EthercatMaster > EK1100 with a EL6652 EthernetIP Master. Plan is to...
392
Once in a while I am asked to look at some Cognex vision programming/cameras in our plant from 5 - 10 years ago. It seems every time I open up a...
1,736
Good Morning , I'm new to Cognex Insight Vision Suite Software. When I connect to my 3 cameras , I only have 1 with the Spreadsheet tab...
2,306
