Combined flowmeter / densitometer
Charbel
Jan 2012
Beirut
307
Dear,
I was looking at a BOQ developed by one consultant for a brine water network, he is using flowmeter / densitometer...
can we find a combined flowmeter / densitometer? and what type? maybe coriolis ?
thank you!
charbel
You should look into massmeters like Promass from E+H
Proline Promass 83F Coriolis flowmeter
Highest process safety – immune to fluctuating and harsh environments
Fewer process measuring points – multivariable measurement (flow, density, temperature)
Space-saving installation – no in/outlet run needs
Quality – software for filling & dosing, density & concentration, advanced diagnostics
Flexible data transfer options – numerous communication types
Automatic recovery of data for servicing
I will second the Promass 83F. It is a good meter. E+H also has a board that will communicate via Ethernet/IP if you are connecting this meter to a PLC.
Other coriolis meters as well will work. Both the foxboro and the micro motion coriolis meters have hart as well as RS-485 for multiple variables
We use the E&H Promass 83 for Flow/Density/Viscosity and it works well. I would, however, recommend that you get the supplier to look at your specific application before buying/specifying an instrument for this type of job. There are a lot of variables to consider.
Hello Guys, Can anyone share the Combined tube autopilot program If anybody worked with it.. we have newly installed this Auto pilot CT which is...
1,396
I was taught to go to Combined > Make Change > go to Offline > will prompt to save > Save > Exit out of program > will prompt to save again >...
685
Hi All I'd be interested to hear approaches hear on what options you might consider for setting up of the loop control. I'll describe the setup...
2,258
Hi, Just got a specification from a customer that said: "The outlet flow to be controlled by: - A combined flow rate/outlet pressure for all...
4,087
Hi, We received from a system integrator a combined project of 2 1500 CPU's and 2 PC's with OPC connections to the CPU's. We would like (for our...
1,252
