Combivert F5 Error 49 E.Puci
ROAMER_AUS
Jul 2014
Umag
50
Hi all,
It has been ages since I posted here. I have non PLC question if someone may konw the answer.
I have Combivert F5 VSD model 12.f5.b1d-3a0a. It is coming up with error#49 E.Puci. Description: When the inverter is powered up the power stage can not be identified by the control card or the power stage is the wrong type for the control card.
I know it is right type of power board because this problem comes up randomly. Sometimes drive starts and runs 10-20 times OK, and then faults.
Does anbody know by chance How control card identifies power board? Only thing different is parameter SY03 "power unit code", when drive is OK, it is 24, when it faults it shows -1. When I tried to find any type of memory chip on power board, I wasn't able to do so. Only thing that might be something like that is small piece of pcb soldered on the main board by 4 pins (like hybrid boards usually are mounted) but this looks like just like piece of bare board.
Any help is appreciated!!!
Thanks,
Dragan
Hello all, I am working on an old bagger that is giving a EUP fault which is undervoltage and intermittent. Electrical power cycles and gets the...
1,239
Hi Everyone. Not posted on here for a long time, but I am hoping someone can help me. I am doing a differential pressure calculation in a L27ERM...
234
Hello Everyone, I have a issue with communication between two different PLCs. So here is the facts, The Master PLC is Guard Logix 5069 with IP...
89
Hi Siemens guys! I am experiencing SF fault on our S7-300 (6ES7 315-2AH14-0AB0) CPU from time to time. I've checked the diagnostic buffer and...
174
Hello..I am new to Plc.I have Mitsubishi Melsec Fx3Ga-40MR PLC controlling a machine for packing powder.Currently the Plc has issue which power...
143
