Communicate MultiPanel (siemens) Modicon PLC
juanmdx
May 2007
SLP
281
Hi everyone,
I'm trying to communicate a MultiPanel MP277 touch screen (from Siemens) with a Modicon PLC (984), so, I built the proyect on WinCC Flex I choose a Modicon PLC as a drive, then I connected an RS422/RS232 converter to the MP (the converter is from siemens 6AV6671-8XE00-0AX0), then I've the cable wich is also a siemens, it's a 6ES7901-1BF00-0AX0 and then I have the PLC.
The thing is that I'm not having any communication, is like if the MP is not seeing the PLC. I'm not shure if I've everything OK or if I'm missing something.
Hope someone can help me.
Thanks in advance.
Juan
OK, I think I solved my previous problem, but I came out with a bigger one.
The thing is that on connections I choose a 984 PLC, but I actually have a TSX Quantum, but when I choose this PLC all my tags go "Out of Value" I'm using 3X and 4X registers (ex. 3X0001, 4X0090) and eveyone goes wrong.
I checked and WinCC Flex force me to use 6 digits after the X, ex: 4X412345 but there should be only 5, so I'm adding a 0 after the second 4, ex. 4X401234.
I will check if it work this way...
Juan
No, still not working.
I already checked that the switch on the PLC is on RTU as the Siemens manual sais, but still nothing...
Does anyone have a clue of what might be going on?
GeoffC said:
At a guess I dont think you need the second 4 ie to read first register it would be 4X000001
Yes I need it becaus if I write the adress 4X000001 WinCC Flex turns it to 4X1
how to communicate FactoryTalk Optix and Mitsubishi Q Series. I want to know the details of that
41
We are trying to poll data coming from a PLC for remote monitoring we have the IP address of the PLC and the default port number and the path is...
25
590
We have some very old technology in my plant that needs adjusted but I don’t have the equipment. Can anyone tell me what I need to program this IO...
349
Hi Guys, I want to connect my 1769-L36ERM to a different network domain, is it possible to do it using only the dual ports in the Controller? Or...
226
