Communicating with a Siemens TP170A
Tharon
Jan 2007
Other
1,430
Hi. I'm using Protool v6.0 and am trying to communicate with some Seimens TP170A Touch Panels. (Download some language changes for the displays)
I'm using a Laptop with a Serial I/O PC Card. This serial port is set as COM4 on my laptop. When I try to configure the communications in Protool, all I see for options under Serial are COM1 or COM2.
Anyone have any tips?
Also, when reading the help files on Uploading I saw it say that this option was not available for the TP170A. Does that mean that you can't get a file from the TP170A to modify? You have to have the original file?
Info + Numbers:
Protool v6.0
TP170A Part# 6AV6 545-0BA15-2AX0
Socket HS Serial I/O PC Card
Ok. After finding another programmer who had a laptop with a built in serial port, and getting his help to download some changes, I took my laptop back to my office and was poking around with a new cable and an RS232 to Profibus converter.
Turns out there is a very simple setting on my Socket Serial I/O Card that lets you change the COM port number.
I looked everywhere for it except for the most obvious place. I looked all throughout the hardware and device manager settings. Turns out there was a small program running in the System Tray that makes it very easy to change the COM port number. Over a year of using this Serial I/O card and that's the first time I've ever noticed that configuration program.
Now I have it set to COM2 :)
Good morning, I am trying to find the best and most cost efficient way to send data from a siemens s7-300 to a pc through a serial port card...
1,724
Dear All, May I know if anybody here has a set-up like this? A siemens CPU315-2DP communicating with Siemens BW500 Belt weigher integrator over...
2,362
I have a Festo CPU model HC20-60-FST that has an Asi master card plugged into the backplane as well as an 10MB/sec Ethernet Controller P/N...
2,860
Welcome to the automation world. my name is nag. recently we are doing one project that is the extension of the existing project ...
4,810
