Communicating Data from Siemens S7 to a PC
warzok
Sep 2011
Bradford, Ohio
Good morning,
I am trying to find the best and most cost efficient way to send data from a siemens s7-300 to a pc through a serial port card. the customer wants to collect the data from 5 LVDTs on every cycle. what would be my best options to do this. I am new at programming,and new to this site. I would appreciate any helpful information.
Thank you
Why a serial port ?
It may be possible, but I think that it would be the wrong solution for what you ultimately want to achieve.
Serial ports are slow, the S7 PLC needs expensive add-on cards to have a serial port, and even on PCs serial ports are beginning to disappear.
Try to explain in detail what you want to achieve.
Hello, I am at customer site. The PLC is on and well, ie. no issues. The customer had to resplice a Devicenet cable not too long ago and the...
1,391
Hi, my factorytalk viewpoint is not displaying any data relating to tags on my plc. They display fine on my client which is on the same host...
4,184
Hi, I've been given a task of loading all the data from 3 S5 PLC's to one S7 PLC which will be used as a bridge to help speed up the...
33
15,034
Dear All Please help me about Below picture problem.PLC not communicating proper.
182
I need to recommend a PC to replace a customer's old Windows 7 computer. The only thing I need to think through is the serial com port to...
21
696
