New PC with Serial Com Port for Communicating with SLC 5/03.
"But they will ONLY work with DH485 protocol (either RS232 or RS485 electrically)"
Geeze, that's right. I got my 485s confused. I really should know this stuff by now. I'll get a little burst of SLCs, then I won't see any for a year. Most of the time all I do is hook up to the PLC to troubleshoot.
So let me ask the question this way: You walk up to a SLC 5/03 connected to a PC through the DB9 connector on the PLC, and the same on a card on the back of the PC, about 25' away. The PC is a Windows 7 machine, and it is old and abused and the customer wants to replace it with a newer, more reliable machine. You don't have to worry about the driver end of things. The machine's manufacturer will install the driver remotely. You just have to pick out the card to put into the PC to insure the communication with the SLC will be possible. How would you go about making a recommendation of which card to purchase for the new PC?
(Btw, I have a whole backpack full of Mark's adaptors, along with a bunch from TW Controls)
If I needed Serial in a modern PC (laptop) or something I would either use an FITI Rs232 to USB Adapter or one of these Adam Serial Device. Although if it was inside a cabinet I would spec and IPC with a Serial port if I could, or use the ADAM mounted on a din rail .
problem with some serial devices is they need DTS support and the cheap UARTs don't support DTS correctly, with industrial you also need 433 or 485.
I need to recommend a PC to replace a customer's old Windows 7 computer. The only thing I need to think through is the serial com port to communicate with the SLC 5/03. The old PC is connected to the DB9 connector, so I'm assuming just a standard serial com card, and the cable is probably wired as a null-modem.
A quick scan of the internet... it's hard to find a PC with a DB9 Serial com port. Any recommendations? This PC is located in an office, so going with a fan-less industrial computer might seem a little odd (like the ones at OnLogic.com). Any better sources? The only other consideration is having a 2nd ethernet card.
Thanks.
Speak to Distec ( Distec Ltd ) they can do you a small windows 10 IPC with serial or if you want expensive german build quality speak to Beckhoff they can do you similar with like of i7 CPU large SSD's etc.
Why not just go back with the same? Can you find the same thing but in better condition? it was maybe a year ago I had something similar and ended buying a new old stock from flee-bay (ebay)
Odds are its just the 1 million Windows updates that have made the PC unreliable
And thank you all for the mentions
Update: The serial card worked great. I set the DIP switches to "RS232", then downloaded RSLinx Classic to check communication. DF1 Communication was established. I closed down RSLinx and they remotely took over from there.
i have a dell laptop with a real com port host OS is windows 10. Running VB 6.1.42 I cannot get the serial port to configure in VB. Please Help...
1,030
Hello, I am programming a Master Slave Serial Communication Protocol (SIKONETZ 5) for SIKO AP05 (Absolute Position Indicator) by using TwinCAT 2...
1,321
Hello All, I have a GE Fanuc PLC ( CPU: IC200CPUE05), we are using a serial communication link with SNP protocol to communicate Cimplicity with...
3,369
Hi All I have a Bl600 Bar code reader I can not make how to send the data to a excell cell using the seria port each time it trigger does any...
1,220
I've got a couple PV1000 (series C) panels, both color and non, and neither of them seem connectable. They're from old projects my company did...
3,547
