virtual box serial port com 1
jimcav
Dec 2004
new jersey
229
i have a dell laptop with a real com port host OS is windows 10. Running VB 6.1.42 I cannot get the serial port to configure in VB.
Please Help
jim cav
From what I gather, from win 10 the way the serial port driver has changed, that is why USB to 232 converters had to upgrade the drivers, so I suspect that a real serial port will need a newer driver as it may not be supported in win10.
perhaps dell have some updated drivers if they still fit serial ports, is this a new laptop ? if it is not & dell do not supply a driver then it's probably a no & you will have to use a USB to serial. I have a dell with legacy ports, however, that is running on win 7 so does support the old 232 ports.
Actually, I have just googled it & maybe this link will help, like Disabling UAC, having the right runtime libs etc.
https://superuser.com/questions/1788915/windows-10-rs232-serial-communications
DR it's a real port, dell will custom build laptops to support many types of hardware but I doubt that serial would be one of them now but they did a few years ago, I still have my Dual core dell with real serial port & pcmcia slot.
Run it on win 7 for legacy software.
That's why I asked if it was new.
If in your hardware it says it's working then it could be user access control so disable it, perhaps the driver will not work with win10, perhaps try a simple coms program to another PC to check if it can then send/recieve information, if so then it must be the libraries I would think in VB. what version of VB are you using.
It may be that this is an incompatibility issue with the built-in Dell COM port and VirtualBox (that's what I got from the link @parky posted).
If so, then you could spend a long time shaving that yak, trying to sort it out.
A simpler solution might be to buy, beg, borrrow or steal a USB-serial dongle, and configure the VirtualBox to "own" that USB device, so the Host Dell Windows 10 OS will not even see the USB device when the VM is running. Then the Guest VM will be able to use the USB device as if it was directly connected to the VM, and the VM would then configure the USB serial device for its own use.
Not an ideal solution, but I suspect OP primarily wants a working COM port, and knowing how to make VirtualBox work with this Dell built-in COM port is irrelevant once they have a COM port that works.
I had a similar situation with a built-in network adapter on a laptop that would not work for me in a VirtualBox VM; I obtained a USB-ethernet dongle and assigned it to the VM; problem solved.
Are virtual machines dependant on the virtual box version on which it was created ?
1,543
I've been using Oracle's Virtual Box in Win10 with great success for my WinXp stuff until Oracle recommended a maintenance update to v6.1.28...
1,501
Hello everyone! I have a problem connecting to plc5. I have an old 1784 PCMK card and a new industrial laptop with a PCMK card slot. The laptop...
5,069
I am trying to get c-more touch screen software to download to a ea3-t6cl. the c-more software is running on windows 7 virtual box. the virtual...
1,506
I am trying to get factory talk m.e. to work on a virtual machine created in virtual box, having trouble getting it to work in a shared folder, do...
1,654
