communication between Foxboro IA series and SLC503
alielectrical
Mar 2003
Toronto
47
I have a requirement to get the digital I/Os to communicate to SLC5/03.
Presently the signals are available on IA Foxboro system.
I can do hardware interface but client prefers network communication to take care of all future signals.
regards,
ali
Does your I/A system have any of the newer 200 series FBM's (Field Bus Modules) ?
Are you using CP60's or higher?
If so, about the only communication protocol that both systems can handle is Modbus. You will need to add a Prosoft modbus module to the 5/03 and a FBM224 to the I/A system. The FBM224 uses RS-422, but there is supposed to be a Modbus TCP module available soon, check with your I/A rep, it may already be out.
If you I/A system doesn't have any of the new I/O, then you will need to obtain a Modbus Integrator or gateway on the secondary market. I believe these are no longer available from Foxboro.
You can choose a Prosoft card here: LINK
Dear All, We currently using LG PLC (Type K120S; Model K7M-DR60U). The unit already has built-in RS-485 communication port. This unit then...
5,300
Hello, I am currently in the final week of my internship and I have encountered issues with communication between a PowerFlex 700 variable...
37
I have Woodward Controller EASYGEN-3500XT and Phoenixcontact make IO CAN-CUPLER part no: 2702230, Analog Input card: 2861412, Analog Output Card ...
47
Hello Everyone, I have a issue with communication between two different PLCs. So here is the facts, The Master PLC is Guard Logix 5069 with IP...
112
153
