Communication between Magelis OIT and control logix PLC
Yna
Jul 2012
Metro Manila
37
Hi guys, we have a XBTGK magellis OIT. We're trying to communicate it with control logix AB PLC. I am having a problem communicating and " PLC return error code 08" displayed on the OIT. No values displayed on the display but there is no no com indication(the triangle with exclamation mark).
I used the EIP ControlLogix - Bridge as a driver. I follow the help file in configuring the equipment and the adressing format. Example of configured address: RealTag01 (this is exactly the same with the AB PLC tag).
Can you help me how to fix it? Thank u so much!
I am having trouble running the application throught my PLC, tm221me32tk with magelis HMIGTO6310 I have prepared the plc programme, also created...
111
I have Woodward Controller EASYGEN-3500XT and Phoenixcontact make IO CAN-CUPLER part no: 2702230, Analog Input card: 2861412, Analog Output Card ...
31
Hello Everyone, I have a issue with communication between two different PLCs. So here is the facts, The Master PLC is Guard Logix 5069 with IP...
91
116
I'm trying to write a data in Arduino using MODWR function block .I used the code I got from online for both PLC and Arduino. I made the wiring...
117
