Communication between paneview and micrologix through ethernet issue
Using the Shielded twisted pair cable is only solution ? or can we do something with UTP cable also.Please confirm whether i have to go for Shielded twisted pair cable otherwise just a try for STP cable.
Ok if my understanding is right, you have changed the cable 3 times already so I think we can eliminate conductor breaks or other issues such as that. You have checked the equipment so you know that the devices can communicate. Obviously you must be going by some problematic noise sources. Have you maintained some separation from power cabling and other noise sources? Do you cross over noise producing cables perpendicularly to limit noise? There are always other options to look at, but you may spend a considerable amount of time tracking down where noise is being injected. If you have not already, you may want to turn off that DC drive and see if your problems go away. If you have other devices that you can do that with, you may at least determine where the problem is coming from. After all that you may still need to install shielded cable. That may actually be the quickest solution to your problem.
Hello, I am currently in the final week of my internship and I have encountered issues with communication between a PowerFlex 700 variable...
240
I have Woodward Controller EASYGEN-3500XT and Phoenixcontact make IO CAN-CUPLER part no: 2702230, Analog Input card: 2861412, Analog Output Card ...
64
Hello Everyone, I have a issue with communication between two different PLCs. So here is the facts, The Master PLC is Guard Logix 5069 with IP...
135
i have two plc 1. s7-1212dc/dc/dc ip; 192.168.0.1 2. s7-1500 1513-1pn ip; 192.168.3.2 i need to get data from plc1 to plc2. any idea how to do...
189
167
