communication between PLC-PC-micromaster
juan
Apr 2003
50
I was wondering if anyone could explain me a little bit about the connection over the RS485port from our PLC (S7-200 siemens) to our micromaster frequency variator.
In the following attachment you see that we send caracters over our RS485 port to another device (mcromaster or PC) The PC is not programmed to understand these caracters I think. Is this a special code so we can drive our motors through our micromaster frequency variator?
Which protocol is used to drive the micromaster over this port?
Where can I find the technical information abot this particular protocol?
Thanks...
Juan
but ...
Thanks,
But the schematic shown above, is this a typical communication between a PLC and a micromaster?
Hi
Normaly is using Profibus communication betwine Plc and F-converter. But in PLC S7-200 can not run like a master. You need S7-300. It is posible by USS protocol but is not friendly, and also you cant run USS and PPI protocol in the same time. When PLC is in stop mode the port is automatic configured for PPI communication, and if you use USS protocol when plc is in run mode is not posible tu see status by this port. You need Profibus card EM277 to see status or PLC with too ports.
By
155
I'm trying to write a data in Arduino using MODWR function block .I used the code I got from online for both PLC and Arduino. I made the wiring...
152
Communication between devices will stop working for a certain period of time. I caught the error message using WireShark. I cannot identify the...
113
I am trying to establish communication between Siemens PLC 1500 and Matlab. I followed a tutorial on youtube at this link: But when I got to the...
364
Hi all, I don't have experience PLC programming so it might be a stupid question. I made a socket request to PLC and there is no problem to read...
893
