communication between s5 and s7 via H1
plasmo
Dec 2003
Hi, im new in this forum. I've got a problem with communication via H1 between s5 115cpu928B and s7 300 cpu 315. I use in s5 cp1413 and in s7 cp314. In s5 program i use fb 244, fb 245 for recive and send. In s7 a use fc5 and fc6. WHen i starting communication is establish but i have no transfer data. Cp1430 online test look ok (status for job is send all and recive all activ, no errors). In s7 i see message: send data on ethernet and waiting for recive data. I dont now what can i do. Every look ok but not works. Can anybody help me?
Thanks. Sorry for my english.
Plasmo.
There could be a number of problem. I like to set up the send block, in the S7 with a N/O bit that gets set in OB35 that will send every 100ms. I connect the receive up to receive continuiosly. Are There errors on the Ret_Val handles? It should say "waiting for data" Did you set up a CONNECTION in Netpro? Are your Mac addresses and IP address correct and connected on the SAME subnet? Is there a switch or router between that could be blocking the data. If you can, try to set the PLC's near each other and connect them with a crossover cable or a hub with regular ethernet cables. Under the CP343-1 DIAGNOSTIC tab, is the H1 (ISO) configured and running? You can setup the send on one side to the receive on the other, one at a time, if it makes it easier for you. I am more familier with the S7, I forgot most of what I knew in S5.
Hello, We have a big problem of connexion between laptop & the micrologix 1400: we have this installed connexion below: Please See picture 1 In...
1,794
Anybody have any idea how to connect Allen Bradley and Seimens PLC via kepserver software? Need Help
1,618
Hi everyone! I'm working on a project where I need to communicate a Quantum with a RX3i PAC. The only available driver on the Unity Pro v2.1 (used...
2,941
Hi Everyone, I need to know how to communicate panel view 600 plus with slc 5/03 via serial cable NC-13 if any body know this technique please let...
2,513
Greetings I need to communicate a PLC5/80E to a Compactlogix L35E via Ethernet. I found in the AB knowledgebase a note that explains how to...
5,182
