Communication between Siemens 1214 and Micrologix 1400
akky
Apr 2020
Mumbai
29
Hi there,
I am trying to communicate between Siemens 1214 that I have and a Micrologix 1400 on the other end through CIP protocol.
I downloaded the Cip Client FB demo program through Siemens website.
I am getting the communication status as 7002 (OK).
However, the quality for the tag that I am trying to read is showing as 'B' (Bad)
even though the address is correct.
What can be the issue?
Attaching the screenshot of the runtime
I cannot, since I cannot change the programming on the Micrologix end. So i cannot use MSG instruction over there to use Modbus TCP
It is recommended that the instruction is placed in Program cycle or cyclic interrupt, is that the case?
Your FB looks to be not optimized while the demo manual/instructions show optimized block, could that be an issue?
I have already placed it inside cyclic interrupt, tried optimizing the block, now the status shows 16#7003 for a while and then goes into error. The error code is 16#8401 which means
i have two plc 1. s7-1212dc/dc/dc ip; 192.168.0.1 2. s7-1500 1513-1pn ip; 192.168.3.2 i need to get data from plc1 to plc2. any idea how to do...
125
I am trying to establish communication between Siemens PLC 1500 and Matlab. I followed a tutorial on youtube at this link: But when I got to the...
355
i have TWO PLCS ( ONE PLC M258 SCHENEIDER ) AND OTHER PLC IS ( SIEMENS S7-300 CPU314C-2DP ) SOFTWARE USED FOR SIEMENS IS TIA PORTAL V13 AND...
2,049
hi how can i Communication between Siemens S7-300 and Vijeo Citect 7.2 with Ethernet tcp/ip ? please help me!🤞🏻🤞🏻
1,808
Hi, I would like to ask, does anyone of us have experience in communicating by ethernet between Simotion D435 and Wonderware InTouch? Is it even...
1,349
