Communication between two s7300 Ethernet
pokajy
Mar 2008
Turkish
53
Hi
I want to ask several questions.
1- Is it possible to make communication between two s7300 plc via ethernet, WITHOUT hardware download?
Plc is in run mode, I can't stop it. That's why I'm asking.
2- which block will I use? AGSEND AGRECEIVE or PUT GET or something else..
3- Can I use CP343-1 Lean instead of a normal CP343-1?
Will answers change according to plc? ( Now I have two compact plc with cp343-1 module, I want to learn answers for plcs with profinet ports too )
4- I want to ask for Dp/Dp coupler too. Is it for only two plc? Can I use it for data exchange between 5 plc?
NB. I assume that this is an existing project with a CPU without an onboard ethernet port.
3. Yes you can use CP343-1 Lean.
2. You can use AG_SEND/AG_RECEIVE. PUT/GET require that the active partner is at least a CP343-1 (not Lean).
1. For CP343-1 Lean or CP343-1 you need to download a HW Configuration with a connection defined in NetPro. So that requires a restart.
4. It will be too cumbersome to use DP Couplers for more than 2 PLCs.
I want to realize the communication S7 and pc by cable profibus or mpi I want to know the steps to that allows me to do it
1,267
HELLO ALL. I HAVE A PROBLEM about communication between cpu s7300 DP and S7300 CP. THANKS
4,327
I have Woodward Controller EASYGEN-3500XT and Phoenixcontact make IO CAN-CUPLER part no: 2702230, Analog Input card: 2861412, Analog Output Card ...
34
Hello Everyone, I have a issue with communication between two different PLCs. So here is the facts, The Master PLC is Guard Logix 5069 with IP...
93
119
