Communication for DL350
WallyPrestone
Aug 2005
Torrance, CA
121
Hello,
Need help to change default communication port to Com4, the program default Com1 and Com2, my laptop does not have the com port so I use the UBS Converter to RS-232 and default of BB UBS-RS232 is Com4.
Communication using Direct Logic 5 software
Thanks for the help
Wally
You should be able to change the USB to COM1 or 2
use device manager - Ports - driver advanced setup
Hi all. I have a Modbus ProSoft module in my setup with a capability of 30 clients (0-29), which I'm trying to monitor the Ethernet Connection...
26
Hi folks, I have a Controllogix in communication with a zigbee coordinator using Logix AIO for modbus tcp. This zigbee coordinator have 3 slaves...
101
Hello, i am using profibus as communication between plc and fanuc arm. I can easily send inputs from plc to arm, but i can't monitor any outputs...
41
I have Woodward Controller EASYGEN-3500XT and Phoenixcontact make IO CAN-CUPLER part no: 2702230, Analog Input card: 2861412, Analog Output Card ...
47
Hello Everyone, I have a issue with communication between two different PLCs. So here is the facts, The Master PLC is Guard Logix 5069 with IP...
106
