COMMUNICATION LINL B/W MODICON & S7 300 PLC
shabi
Nov 2005
Dubai
Hi , i have one task i have to stablished communication link b/w modicon & S7 300 Plc over Ethernet TCP/IP protocol. connection medium b/w them is Fiber optic i am using SCALANCE X 204-2 to convert Fiber optics in Ethernet TCP/ip protocol. can any body send me the connection diagrams
You should check with your PLC suppliers. The native Ethernet for Modicon is Modbus/TCP and the native Ethernet for Siemens is Profinet - essentially Profibus over Ethernet. I'm not sure they have directly compatible protocols. You may need a communications bridge.
You can use 343-1 communication processor in S7-300 or S7-300's with integrated Ethernet interface and write your own program to communicate via Modbus TCP protocol. I've tested it with some of applications using my own Modbus TCP Master code for S7 PLC's.
Hi folks, I have a Controllogix in communication with a zigbee coordinator using Logix AIO for modbus tcp. This zigbee coordinator have 3 slaves...
29
Hello, i am using profibus as communication between plc and fanuc arm. I can easily send inputs from plc to arm, but i can't monitor any outputs...
29
I have Woodward Controller EASYGEN-3500XT and Phoenixcontact make IO CAN-CUPLER part no: 2702230, Analog Input card: 2861412, Analog Output Card ...
39
Hello Everyone, I have a issue with communication between two different PLCs. So here is the facts, The Master PLC is Guard Logix 5069 with IP...
98
127
