Communication Siemens s7 and Citect SCADA v7.1
krgb
Mar 2010
Langesund
We are 4 students at Fagskolen Telemark in Norway who are trying to make a project which are using CitectScada and Siemens s7. The project is a color sorter with silos, level measurement, coloursorter (RGB) and electrical driven conveyor belts.
In this, we are not familiar with the connection between S7 and Citect. We are trying to use the PSDIRECT driver from CItect, but are not sure how to adress and connect the S7 and the Citect program.
Is there anybody who can give us a quick tutorial, or send me some links which can bel helpful?
regards,
Garstad-Berg
Have you tried using OPC for this? Here is an OPC Server for Siemens S7 PLC:
http://www.matrikonopc.com/opc-drivers/opc-siemens-s7-plc/base-driver-details.aspx
It will detect your S7 Plcs automatically. All you need to do after that is to connect Citect's OPC Client to the OPC Server for Siemens.
If your Citect doesn't have an OPC Server, install this OPC Server:
http://www.matrikonopc.com/opc-drivers/190/base-driver-details.aspx
and then connect both OPC Servers together with OPC Data Manager:
http://www.matrikonopc.com/products/opc-data-management/opc-data-manager.aspx
Wassim Daoud
Global Solutions Architect
hi how can i Communication between Siemens S7-300 and Vijeo Citect 7.2 with Ethernet tcp/ip ? please help me!🤞🏻🤞🏻
1,806
Hello All, I would like to try Citect and siemens communication. I am new baby on both and so that i need suggestion from all bcos i am...
4,553
Hi, I have some questions about Ethernet communication between Vijeo Citect 7.0 and Siemens PLC S7-300. On the plant, beside 4 Schneider...
6,957
122
Hello Guys, I want to establish profinet communication between siemens plc and my system using python programming. Which python lib can i use to...
389
