Communication with AB SLC 500 with a Red Lion DSP
jmaty23
Mar 2009
New York
49
I am looking to established ethernet communication with an Allen Bradley SLC 500 via ethernet. Both devices are already setup on my ethernet network. I need to know which driver to use in Crimson 3.0???
jmaty23 it depends on the SLC you have. If you have an SLC5/05 you want the DF1 Master. If you have any of the older SLC you want to choose DF1 Master via PCCC/EIP.
Jeremy
Good point, I assumed you had a 5/05 since you said Ethernet. But if you're using a 1761-NET-ENI you'll want the EIP driver.
I chose DF1 Master liek you said. I have a tag setup checking to see if the device is online (isdeviceonline(3)) and it doesn;t seem to be communicating to the plc. Is there anything that has to be enabled on the PLC side to make it work?
Nothing needs to be configured on the PLC side, well other than its IP information. Do you have a data tag mapped to the PLC, and have this tag on the active screen or in the watch window? The DSP is smart enough to only poll the data it needs at the time, so if nothing is needed from the PLC, the DSP will not try to connect to it.
Regards,
Dan
After I tried wiring, I used computer program communication to read the PLC N value, but received a NAK signal. And the DL3500 CHA light keeps...
436
Transfered a program and project from one machine to another and no longer have communication. The 2 machines are twin machines in every way. We...
1,390
Good Morning , I cannot believe I forgot how to do this. It seems like I have been spoiled with everything being Ethernet. I have a SLC 500...
2,769
Hi everybody, We are repairing a stretch-forming machine that we bought heavily used and seriously dismembered. It has a HP computer running OS/2...
20
6,321
Hi Guys, I'm rather new on this forum, I've got a problem with my communication (RS232) with a Schneider (former Berger Lahr) stepper...
1,564
