Communication With Slc 500 Processor
PERSPOLIS
Jun 2002
ontario
295
HI EVERYBODY
CAN ANYBODY TELL ME THAT HOW I CAN USE MY LAPTOP (COM 1) TO GO ON LINE WITH 1747-PIC AND SLC 500 PROCESSOR .
I HAVE WIN XP ON IT AND IF NOT WHAT ARE THE ALTERNATIVES .
MANY THANKS
PERSPOLIS
What software do you have ??
Well for starters you going to need the software (RSlogix500)
Then possibly a AB Personal PC Interface Converter...
You will need RSLogix 500 ver 5.20.00 or above (5.20.00) was the first version to support winXP but i have heard of people using older versions like 4.5.
As long as this laptop has the serial port built in then you shouldnt have a problem with the 1747-PIC but you will need to obtain RSLinx 2.30.00 or higher, RSLinx lite is offered on the AB website as a free download.
IF your laptop doesnt have a serial port and you are attempting to use a USB adapter it probably wont work, a pcmcia adapter to serial might work.
Hope this helps.
It is also possible to communicate via the 9 pin connector using the rs232 driver within RSLinx. Some versions of RSLinx do not offer the 1747 pic driver. You would have to connect serially using a 232 cable and use the RSWho function to locate your processor. It may be necessary to Autoconfigure the driver once you are connected. Good Luck!
RJenkins
After I tried wiring, I used computer program communication to read the PLC N value, but received a NAK signal. And the DL3500 CHA light keeps...
445
Transfered a program and project from one machine to another and no longer have communication. The 2 machines are twin machines in every way. We...
1,393
Good Morning , I cannot believe I forgot how to do this. It seems like I have been spoiled with everything being Ethernet. I have a SLC 500...
2,781
Hi everybody, We are repairing a stretch-forming machine that we bought heavily used and seriously dismembered. It has a HP computer running OS/2...
20
6,322
Hi Guys, I'm rather new on this forum, I've got a problem with my communication (RS232) with a Schneider (former Berger Lahr) stepper...
1,564
