Compact Logix EtherNet
Vehtek55
Feb 2015
Perrysburg, Ohio
I have a 1769-L32E Compact Logix processor. I am using the EtherNet port already. I want to know if I can use the serial port to connect to another device to create another EtherNet port with a different IP address?
You should be able to accomplish what you've described through a serial to EtherNet module. Rockwell had one which is now retired, but a lot of 3rd party manufacturers still make these.
However, could you elaborate on the reason as to why you'd want to go this route? You can create any IP structure with a switch & you wouldn't need to use the serial port.
Cheers,
Vlad
Not sure what you mean by this? 1769-AENTR is an adapter to have a 1769 remote I/O chassis. It does not add a second port to L32E controller.
Good catch... I have never used one and thought it was both a additional Ethernet port and expansion I/O
Are you after a second port specifically or just need to access the device from a different network? Can you use a 1783-NATR or any NATR device?
I have a CompactLogix 5280 a I am trying to figure out which of the Ethernet ports are A and B. Not finding it in the manual and this is a new...
1,203
Dear all Can any one guide me for mapping in compact logix in RS Logix 5000 which I will be using MOXA MB Gate 5105 for converting Ethernet IP to...
1,566
Hello everyone, to get straight to the question, I have done simple programming with digital inputs and outputs but I have never programmed a PLC...
3,578
Hello all! Have an existing 1769-L18ERM-BB1B V28. with full expansion to 8 modules 1--1734-OB8 and 7--1734-IA4. According to IAB this can not be...
1,885
Hello Experts, I have begun working on a new project and am specifying all the components. I am planning to use the AB compact logix platform and...
5,102
