Compactlogix and BootP
WilsonNC
Dec 2010
Murphy
24
I am trying to use bootp to set an ip address in a new Compactlogix 1769-L35 processor. I have a pc running bootp and its connected thru a switch to the compactlogix. I dont see the link lights on the plc or the switch, and dont see any mac adresses in bootp. Tried other ports on the switch that I know work...nothing. Keyswitch in any special position? What am I missing here?
Go Online with the CPU thru the serial port and try to set the IP address. Also is this a new processor?(out of the box)
Shouldn't the link light come on regardless? I manually keyed in the MAC address in bootp, then selected enable bootp. says "timed out"
Agreed: No link LED = no Ethernet connection. Bad cable, bad switch port, bad controller port are all possibilities.
My bad, power supply setting was not switched over to 120VAC. I removed this from a built panel so I never checked it..... Bootp working fine now.
Hello all. I have a 1769-L32E that I am re-purposing. I have unplugged the battery and left it for a while, I have actuated the little pushbutton...
17
4,099
I have a Compactlogix with a 1768-L34 Processor and two 768-ENBT network cards. I assign a IP address b adding a relationship and we are good...
3,493
Hi All, I'm just trying to understand the reason behind something I recently experienced. Background: The system contains 4 CompactLogix...
127
279
Hi everyone, i have a compact logic 1769-L18 PLC and I'm using FTalk View ME for the display. I wanted to do some visualization on Grafana. At...
169
