CompactLogix and CompactFlash Card.
Elcan
Apr 2008
NC
935
Hello all,
I don't have a CompactLogix 1769-L32E to try this, so I will ask the question.
If I have an out of the box 1769-L32E and I replace its CF card with another one from an existing processor, will the new processor have the existing RSLogix 5000 project loaded when is powered up?
What about the IP address?
Thank you!
Not by default. You can store the program to the flash card with the options to load the program at power up. This is done by you via RSLogix5000 (not automatically done). I don't think it will assign the IP address though.
There is a way to assign the IP address via PLC logic, however this would be in the PLC all the time. I'm not sure you would want this in your PLC running all the time because if a user later wanted to change the IP address and didn't change the logic, it would potentially get reassigned by the PLC (depending when that code executed).
However, the existing firmware will be loaded in the new processor, right?
Good Evening , I was given a CompactFlash card that was in a CompactLogix CPU. I placed the CompactFlash card in a Reader , and captured...
1,645
Hello all I want to do some data logging, which I have succeded in doing on my Rockwell CompactLogix directly onto its CF/SD-Card. I just...
2,275
I downloaded a file from AB CF_Write_READ. They tested it using a Control Logix. I have a Compactlogix w/Ethernet. The only other card is a...
2,526
82
Hi everyone, i have a compact logic 1769-L18 PLC and I'm using FTalk View ME for the display. I wanted to do some visualization on Grafana. At...
97
