CompactLogix L18ER and KepserverEx
phuz
Jun 2008
Mohnton, PA
1,044
I upgraded a Micrologix 1100 to a new CompactLogix L18. I've been using the KepserverEx v4.5 and it has been fine until now. If I use the OPC quick client, the data sometimes is there, other times it says unknown, but the quality is always bad, and it says "BAD VARTYPE". I have tried changing it to different processors and different methods, but cannot get good quality out of it.
I tried the KepserverEx 5 demo version, and this showed good quality. Any idea how I can get this to work properly with the version that is currently running?
So I thought of an issue with this older version. Maybe my firmware was too high. I changed the Logix firmware from 24 back to 20. Now all my data quality shows good, but every value is "0".
Phuz,
One thing you need to be mindful of when using an older version of software is that its development and support are not continued. If your application was running as is, with no additions or modifications then your older version of software should work just fine. However, from what you have written, you are making changes through upgrading hardware. This action opens the door to potential problems.
You have indicated downloading version 5 of KepserverEX for which you have indicated good results. My suggestion is rather than wrestle with version 4, which is no longer supported, you should upgrade.
As was mentioned previously, Kepware offers excellent support for transitioning from v4 to v5. Myself, as a distributor for Kepware can offer you additional support.
http://www.eternity-sales.com/Kepware/kepserverex.htm
It sounds like you have the Allen Bradley OPC suite of drivers. If that is correct, I can put together a quote for you based on this information. If you are using additional drivers, please let me know.
Feel free to post your requirements in this thread, pm or email.
Phuz,
Unfortunately, the cost of $900 for the AB suite with KepserverEx was not figured into this budget, and is therefore not an option at this time.
That is unfortunate because Kepware will be raising their prices in January.
How much time are you currently spending on this problem?
I would say that your time was likely not factored into the budget either, yet it is a cost. The more time you spend, the more it is costing your employer / client. Or if you provided a fixed cost for your service, the more it is costing you.
Going to the decision maker and explaining to them that they have an older version of software that is no longer supported with updates or feature enhancement may convince them to go with the newer software. Stating that the problems you are experiencing are a result of adding new hardware that may not be supported by the version of KepserverEX that they have installed should be addressed.
As an integrator, I am the one who eats the cost at this point.
I found a solution by downgrading to v20 in the controller and then changing from Physical non-blocking to Symbolic. For now, all is well and happy, but certainly won't be upgrading any time soon.
I had an L18ER CompactLogix processor this morning that had all inputs (embedded and PointIO) in a "standby" status. The Network Status indicator...
1,210
Beginning last night, I have a CompactLogix 1769-L18ER that will not actually go into run mode. If powered up in program mode, it stays in...
2,526
Hello All, I have a plc that is missing the power connector, and I/O connectors. I cannot seem to find these connectors to purchase. Can someone...
2,464
Good Morning , I'm thinking of using a 1734-IK with a CompactLogix 1769-L18ER. Looking at the manual it looks like that it needs to be used...
1,623
