Compatibility between S7 v5.1 and ...
Aug 2005
Hasselt
60
Hi guys,
I need quick info!
I'm working with Simatic manager v5.1 with SP6, what is the latest version and are they both compatible or do i have to update to work on a project written with a newer version of Simatic manager
The Current Version i think is V5.3 (XP/2000 Only)with SP2,It really depends on how recent the hardware/PC is you are using, Although you can update your hardware Catalog online.
Hope this Helps!
STEP7 is to a relatively forgiving when you want to open a project from a new version with an older version.
Problem may be that the old version do not support the hardware that is used.
If you just want to work with the code, you can allways export to "source" in the newer version, and import that in the older version.
Hi, Just looking for a quick pointer. I want to upload an old program out of a Texas 305 PLC. The program was last downloaded in the 90s so...
2,036
I have a 1756-L55M12 ControlLogix processor which is set to the site standard firmware revision of 16.21 (also the latest revision for this...
4,219
I've come across a system running omeron cx-programmer version 9.42. Am I going to need to find a legacy version of the software to edit and...
68
Hi, Is it possible to for an RIO with Flex 5000 series module, e.g. 5094-AEN2TR, to communicate with an 1756-L72E processor.
103
Hey there friends, recently discovered the world of industrial automation and learned what this fancy PLC can do so i am a super novice. Started...
362
