Compressor Ex 2- Logixpro 500
Kelby,
Your work looks good. Exercise #2 is just another turn of the screw. In order to make this work; you’re going to need a minimum of 3 components. 2 objects to change states (the motors or lamps) and 1 object to keep track of the state change.
Take a look in the first rung of the ladder you just posted. The answer is right in front of you.
Drop one in, click on it and press F1. The help files are very good on RSLogix.
Without speaking specifically about your application, there is never a place where you HAVE to use the latch/unlatch instructions. There are places where it's a good idea, and places where it's a bad idea, and places where it's neither here nor there and down to personal preference. If you can get good results using it, and it makes your code simpler and clearer, use it.
As ASF has suggested, latches are not always the tool to use. Take a look at this 3 rung ladder using the LogixPro I/O Simulator. Hopefully it will inspire you. If not, we are still here for you.
I am doing the Logixpro 500 simulator for exercise 2 using dual compressors. I can get the dual compressors to swap but am now needing to have...
2,399
Hi folks, i'm pretty much new on this topic and i need some help with the dual compressor part 3 and 4, currently working on part 3 i cant make...
20
5,115
Part 3 – Coping with Large Demands for Compressed Air Your current program should be suitable for maintaining the desired pressure range as long...
2,753
Hello Forum Friends, I need help, I have to do the Dual compressor in [LogixPro], and the truth is that not how you use this program, please HELP...
21
8,924
First i would like to say that this is a grat site. I was viewing the thread on the Dual Compressor Simulation for Logixpro. I have run 150 mph...
3,518
