Conductive Level Switch vs Float Switch
Charbel
Jan 2012
Beirut
307
Dear,
application is for TSE water coming from a treatment plant to be used for irrigation. I will be controlling the pumps based on the level, material for both instruments will be selected to be suitable for the type of fluid in the tank.
Operation wise, which one do you think is better?
thank you!
charbel
How reliable do you want your system to be? Do you want it to keep running if one switch fails? If so, use both types of switch, with a selector switch to switch the controls form one to the other. Then a level device failure is fixed by simply turning a switch.
...assuming you are continuously cross-checking both switches against each other. If you aren't you have a 50% chance that the switch you change into is also failed. You could witch between them every month as a part of normal operation. That decreases your exposure but doesn't completely eliminate it.
Keith
I've had better experience with simple float switches if those are the only choices.
Better yet, go with ultrasonic, and use Lancie's switch idea to select floats as a backup.
I have had a few instances where a float switch has sunk, or been fouled and not operated as expected.. I usually use a conductive level controller, but quite often make my own probes to add some weight and distance between. If you are looking analogue, current trend here is hydrostatic PT's...
Dear, I am working on a project that pump water out from a existing well and send it to a high level reservoir. From the high level reservoir...
3,951
Hi all, i have this project in which we have to replace an AB 400 amp contactor used as the panel power contactor that is 20+ years old with a...
3,637
Could someone suggest any instrumentation to internally view non conductive material? Example : Validate a centered wick in a candle internally...
1,480
WHAT difference between Conductive panel and steel panel see the attachment.
4,965
Dear all, I am not sure whether I use the correct term. What I want is to detect whether a metal strip (5" long) sits on both point A and point...
18
8,013
