Conecting CPU S7-212 with Omron NS12 via HMI-GWY module
fribeiro
Dec 2003
Almada
40
Is there anybody tried before to use the HMI-GWY module to conect a Siemens S7-212 with NS12?
Well, i can configure the module HMI-GWY with the blocks i want with success, but i cant get communication!!!!
Wich cable should i use in S7 side? The PC/PPI converter or the normal 2 lines cable with Siemens connectors?
Any help should be appreciate! Thanks.
Has anyone ever tried to connect an HMI to a Yaskawa A1000 VFD? If so, what HMI did you use and what communications protocol? I want to try to...
2,086
Looking for some help on the red lion side I was able to diver out all the port settings to get the hmi to talk to elc having the are-485 light to...
1,109
Hello, I'm trying to conect this devices with Modbus RTU using Somachine basic but I don't get any response. The speed, parity, bits and timeout...
9,778
Hi i'm new to this forum, and not familiar with plc therms in English. So please write with this in mind. I will try to connect my labview...
2,282
Hi Dear all i am workinh with plc i have controlled a single bit of digital output module.now i want to on/off the tubelight using this bit please...
2,082
