conecting MICRO MEMORY CARD to plc
mansoreh
Apr 2004
17
dear friend
we bought a SIMATIC S7, MICRO MEMORY CARD F. S7-300/C7/ET 200S IM151 CPU, 3.3 V NFLASH, 64 KBYTES (6ES7953-8LF11-0AA0)
for cpu 315-2dp(it is unpacked,I don't see what is look like) and I want to know should I buy any extra device for memeory card?
how can i connect memeory card to plc and use it please explain it
I am compeletly novice
Hi, there,
You don't need to buy anything extra for MMC card, just plug it in the S7 cpu, then download your program and do your debugging just like before, no much difference than the old type S7 cpu. the only difference is your program will store in this MMC card , and the cpu can't run without it.
Has anyone ever tried to connect an HMI to a Yaskawa A1000 VFD? If so, what HMI did you use and what communications protocol? I want to try to...
2,085
Looking for some help on the red lion side I was able to diver out all the port settings to get the hmi to talk to elc having the are-485 light to...
1,109
Hello, I'm trying to conect this devices with Modbus RTU using Somachine basic but I don't get any response. The speed, parity, bits and timeout...
9,764
Hi i'm new to this forum, and not familiar with plc therms in English. So please write with this in mind. I will try to connect my labview...
2,280
Hi Dear all i am workinh with plc i have controlled a single bit of digital output module.now i want to on/off the tubelight using this bit please...
2,081
