Confirmation about XMIT and MSTR for Quantum 113
gwgps
Dec 2013
Kern
For Quantum CPU 113:
XMIT - Instruction used solely for Modbus RTU (or similar) and not Modbus Plus
MSTR - Instruction used solely for Modbus Plus
Are the above Modbus-related instructions correct for Quantum?
Because of their function, are the above instructions not interchangeable?
If a serial cable is connected at the Modbus port (not Modbus Plus port) of Quantum 113, XMIT instruction has to be used and not MSTR.
I'm trying to summarize post's title Modicon Modbus Quantum 140 CPU:
http://www.plctalk.net/qanda/showthread.php?t=58150&highlight=Modicon+Modbus+140+CPU
Hello guys, is there any way to remove all those prompts when downloading a program to PV800 HMI? First prompt - Stop the loaded application...
2,976
Hello, I am trying to verify the following info from a CAT modbus map. I'm having issues getting meaningful data from these: Total Fuel...
3,556
I have been requested to code an operator set point entry check as follows. This may be simple but has me baffled at present. control system...
2,895
Hi, i'm trying to create a popup screen which will appear only when a certain tag in the plc is active. With ME, it'S pretty easy with Global...
18,609
I just wanted to be sure I'm understanding this correctly as it looks weird to me. The line in the middle is turning this into a "or" function...
1,805
