TheWaterboy
Has anyone successfully connected a 1785-KE 15 pin serial port to a modern radio RJ45 port using 3 wire standard Tx,Rx,Gnd? No Handshaking?
I am successfully using a 15 to 25 pin connection with some handshaking pins tied together like is often done on an older radio, but I can't make it work with this new (MDS ORBIT) radio.
I'm missing something but just can't see it. If anyone has done this successfully can you share your cable pinout and KE Switch settings?
