connect OP27 to S5 95U, 15 pins plug
brunovinyl
Dec 2005
belgium
I have to make connection between OP27 and S5 95U . I have to make the cable, the are in different room. How and wich connection do i make, using the 15pins plug on the S5 and also using the 15 pins connector of the OP27.
I have to connect 8 cables i gues, but wich ones ?
Thanks for any helping lead; I'm very new in S5 and just start learning.
Brunovinyl
cable between s5 105u and op27
I have to make connection between OP27 and S5 105U . I have to make the cable, How and wich connection do i make, using the 15pins plug on the S5 and also using the 15 pins connector of the OP27.
I make cable between op27 and pc (25 pin to 9 pin) and work currectly.
Greetings, I had an issue with a RIO rack 2 and IFM I/O Link dropping on my network. I would loose connection for a second or 2 then they would...
93
Hi friends, i need a help to know the procedure and steps to connect Lenze i700 to PC for parameterize. i tried with lenze easy-starter using LAN...
53
Hi, We have been facing a issue with SCADAPack 474. Configuration is like below. RTU 474 + 6103 PS + 5606 IO Mix Module + 5414 DI Module Only...
73
364
124
