Connect Simatic Field PG M3 to S5
Sam Kennedy
Apr 2015
Newcastle, UK
I'm attempting to use a Simatic Field PG (6es7715-1dd20-0ce3) to connect to an S5-100U CPU .
I've tried using the step5 software in DOSBox but I was getting communication errors (something about the frame being the wrong size), I've now installed Windows 98 as a virtual machine, but now I'm just getting 'PLC Timeout' whenever I try and bring the PLC online.
My COM1 settings are:
19200bps
8 data bits
Parity: None
1 stop bit
No flow control
Any ideas on how I can get this to communicate?
I have no ideas how to get the old STEP5 (v7.x ?) to work on a new PC.
I am guessing the COM1 settings in Windows or DOS are irrelevant. The PG port on the S5 CPU use 9600 baud and AS511 protocol.
If you cannot get it to work, consider S5 for Windows from IBH. They also have a USB-S5 adapter that works with new PCs. I think that maybe their USB-S5 adapter even works with STEP5, so it might be worth a try.
Congrats.
Surprised that you have got it working, though. I am guessing you are using the serial RS232/TTY adapter 6ES5734-1BD20. I have heard that is tricky to get to work if it is not connected to a real serial port.
Hi guys, Could i connect simatic WinCC runtime with Micrologix 1400 PLC via Modbus?
1,247
Hi, guys, how’s going? We have one SIMOTION D435 machine. D435, PLC and HMI are connected via Ethernet cable: D435 X150 (IP:192.168.214。。。) PLC...
4,367
Hey everyone, Can someone please tell me how to connect to Somatic HMI OP 270? the OP is 6 inches and the cable I am using is PC Adapter MPI. I...
2,281
Hi, all. We have one AB drive (powerflex 525) and one SIEMENS plc (simatic S7-1200). Is it possible to make a connection between them via...
10,671
Hi guys, Good day! I just want to verify something. We are to upgrade an S7-400 stand alone instalation to a Fault-Tolerant S7-400 system. We...
1,736
