Simatic Redconnect for Wonderware?
ry_fern
Jan 2008
Caloocan City
44
Hi guys,
Good day!
I just want to verify something.
We are to upgrade an S7-400 stand alone instalation to a Fault-Tolerant S7-400 system. We also need to make the existing Wonderware HMI to be the same.
I'm thinking that all I need are Simatic Redconnect and CP 1XXX cards to make the Wonderware HMI fault tolerant. Am I correct or am I missing something important?
I was able to use redconnect before and I know that for Redconnect to function, MAC addresses are used instead of IP addresses. However, I don't remember Wonderware having a driver for Siemens MAC address. That's why I am asking the above question.
Hoping for your opinions. Thanks.
I think that Wonderware uses connections setup in Simatic Net. If that is the case, then you will not setup the conenction details (IP or MAC address etc.) in Wonderware but in Simatic Net.
It is possible that Wonderware has a direct driver that does not use Simatic Net, but with Redconnect you will be using Simatic Net.
HI i would like to know how to get a variable that will store the amount of times a program has been executed. The issue is I have 3 DBs for 1 FB...
99
Dear sir, I am using SIMATIC 300, CPU 315-2DP , (6ES7 315-2AF03-0AB0) VIPA 603-1CC21 A1.0 RAM 32KB, Firmware=V4.0.8 The problem Im using MPI...
177
Hi, I received this SIMATIC S7-300 training kit for maintenance. When I power it up, the PLC doesn't go to RUN mode and the STOP mode led is...
313
I'm trying to build my Classic Step 7 programming skills this weekend. I get stuck on little things that are not covered in YouTube tutorials. I'm...
327
I am utilizing both HMI and SCADA for my project. Both HMI and SCADA have identical tags. When I modify the tag value on HMI, it is reflected in...
166
