Connect to Mitsubishi PLC over Internet
Big_Robo
Nov 2016
England
81
Hi all,
Trying to find the best way to connect to a PLC over the internet, I'm in England....PLC is in Ireland and need remote access. How does one go about this and it is an old PLC programmed in GX Developer if that makes a difference.
Thank You
You could look into the **** product line. I have several in the field and they work great. Is your Mitsubishi PLC Ethernet equipped? I am guessing no, especially if it is an old PLC. I have an FX series PLC connected to the **** using RS-422 so serial communication can be done as well.
edit.... I guess I can't say e_W_o_n?
I'm guessing the *** is E W O N ?
I do this by getting my customer to connect their laptop with GXDeveloper running, to the PLC then use Teamviewer to log in with the supplied password, this is good for the occasional troubleshoot, maybe this would be an answer?
Steve
First, you should clarify if you want to connect to a remote PC with GX Developer installed and with access to the PLC, or you want to connect to the PLC directly.
Also, you have not explained what PLC model is and which type of communication port it uses.
Hi all, thank you for the responses. I do believe it has Ethernet comms which makes it a little easier. We have been asked by the equipment owner that he doesn't want the software on site as he doesn't trust his employees.
I will have a look at suggestions thank you all.
Hi everybody! Im meet a big problem that my PLC is FX1n 24Mr and he has an Rs422 Com port, and the HMI is Delta TP04P series has Rs485 2w...
2,438
I WANT TO CONNECT A DELTA TP(PANEL) TO MITSUBISHI PLC MODEL NO FX-128MR .I DONT KNOW ABOUT THE COMMUNICATION CABLE AND CHANES I MUST DO IN PLC AN...
5,085
Help, help... I want to connect a PC installed WinCC Siemens to PLC Mitsubishi MELSEC Series Q3A through communication is Melsecnet 10. Which...
5,215
Hi everybody! I have 2 Mitsubishi Q series PLCs that have built-in IP addresses of 192.168.3.xx and both of them have Ethernet modules...
855
Got a used with warranty Q064UDEH It is not going to have the correct parameters to allow me to Connect the Ethernet and download the program...
403
