Mitsubishi Q064UDEH First Connect
asterof
May 2007
Califonia
554
Got a used with warranty Q064UDEH
It is not going to have the correct parameters to allow me to
Connect the Ethernet and download the program.
What is the procedure on a first connect to set Ethernet IP and Node and Station address's
PS Mitsubishi is not my normal cup of tea
Hello Asterof: The Q964uDEH does not support EtherNet/IP adapter.
Maybe you can program it as a Modbus TCP server and the Rockwell PLC as a Modbus TCP Client or viceversa.
You should be able to connect with uSB & set the ethernet up there I think from memory you need GXconfigurator tool to set the Eth up. As Afredo states may not support EH/IP
Hello! If someone can help me with the following problem. I can't change the phone number. Do I really need the interface (AL-232CAB - Programming...
47
how to communicate FactoryTalk Optix and Mitsubishi Q Series. I want to know the details of that
41
I'm at a new job as the sole control engineer and trying to piece together where my predecessor left off. One machine I'm trying to get online...
105
I'm looking to get some spare keys for this PLC. Does anyone know a source or have a part number? My searches are turning up nothing at the moment.
77
