connect two PLCs MPI->Profibus DP
Pandiani
Apr 2005
Tz
718
Hello,
we have two PLC in our small laboratory. One has CPU 315-2 DP CPU and other CPU 314. Is it possible to use profibus cable to connect these two PLCs (use DP connector on first and MPI connector on second) DP to MPI. Since other CPU doesn't have MPI, is it possible to connect DP cable to MPI interface. Is there any possibility to mess things up, I assume it won't work, but I'm afraid to try...
You can connect these plc's via MPI. (Left port of 315-2DP is by default MPI) It is then possible to exchange some data between the two via global data. We connect plc's like this all the time. Make sure the plc's do not have the same MPI-address. (Hardware configuration)
Edit: Make sure to use profibus connector's. (Siemens/Phoenix). On both connectors set the end resistor to on. If the plc's are on different power supplies it migth be a good idee to use repeaters. (Seperating the two power supplies). For a small office application this might be overdone.
Ok, thanks, I assumed it's not possible to use Dp port on one and MPI port on other PLC. However I have profibus DP cable. Is it possible to use DP cable to connect two PLC via theirs MPI ports?
I have two S7-200 PLCs (CPU 224) connected to a HMI (mobile panel). Together they form a MPI network that is connected through RS-485 connectors...
4,749
I was given this task to connect out PLCs to the network wirelessly so they can use the data that is on the machines. I have ben given the...
17
4,124
Hello everybody, I work in the field of industrial computing and sensors. However, I am not an automation specialist. My expertise is more on the...
2,127
Yup they don't have any Ethernet posts on them but would like to try and see if I can get them to connect to a network to get certain info on the...
2,408
Hi all, how many plcs can allen bradely panel view hmi connect get data for mimics
7,062
