connecting a thermocouple directly to SM331(siemens)
Sandor-CRX
Oct 2009
Timboektoe
22
Hello guys,
I have a thermocouple with a green wire which measures a temperature 0-1100 degrees. I dont have any information, only the color of the wire. no data or manufacturere
This thermocouple was connected to a digital microcontroller which converted the mV signal to mA and this was connected to the PLC. The controller was defect and now I want to connect the thermocouple directly to the analog input of a SM331 card.
Question1: Is this possible?
Question2: Looking at the temperaturerange and color of the wire, I believe it must be a Type K thermocouple. What is the measuring type I must choose for the analog input--> TC-I, TC-E, TC-IL, TC-EL or just E (voltage)...
I really can't find any good info about this matter.
Thankss
If it is a type K thermocouple then it will put out about 40 micro volts per deg. C. Also, that will be at just above 0 current. Honestly I don't know for sure but I would be willing to bet my pay check that that a thermocouple hooked directly to a plc will not work. In 25 years of industry I have never seen a hookup like that. The plc inputs are just too insensitive to read a thermocouple. Thats why the ampilifier was there in the first place.
If you do get that to work I would love to hear about it though.
Jim
Jim
what about plcs which have thermocouple inputs card? aren't they connected directly.please clear my doubt
Have you looked at the s7300_module_data_manual? link to US version http://tinyurl.com/23kb5cj (from support.siemans...)
There is a section about using/connecting thermocouples and a bit of theory as how TCs work. (4.6)
It looks like the difference between the -I and -E is where the Cold Junction compensation (CJC) sensor is. If you have a CJC device wired, then you use the -E. If you want to use the internal compensation short the CJC terminals and use -I.
As to the L, setting I didn't read too much, but I imagine that has some thing to do with the type of compensation you have .or else the representation of analog values.
Clarification
I know in recent times that some manufactures are making cards specifically for certain devices. ie Thermocouples, pressure sensors, etc. etc. Thats not the impression I got from Sandors post. Forgive me if I'm wrong but I thought the SM 331 was your basic run of the mill 4-20 or 0-10 input card. If it is not then I stand corrected and retract my previous reply.
If you purchase specific hardware for your plc like a thermocouple card. Which by the way is not by any strech of the immagination a standard input card but rather a thermocouple amplifier that has been modded to fit in a plc chasis. Then of corse you can hook a thermocouple to the PLC. I'm talking about hooking a thermocouple to a standard input card as I thought Sandor was also talking about.
Also type K thermocouples dont function on resistance they are bi-metal. They actually generate a micro voltage. So unless you have a micro voltage reader then just pumping 12 VDC into a thermocouple isnt going to work.
Bornwild, I hope this clarifies my previous post.
i connected my thermocouple direct to an S7 300 AI card and configured it in the hardware configuration of my S7 400 CPU i am running PCS7 as the...
3,076
Greetings to all! As I am new to Honeywell's PLC usage, perhaps someone with more experience could help me. My assignement is to collect data...
4,570
Good Day to all of you, this is my first post, i will try to explain as best as possible, english is not my natural language. I am performing an...
49
96
Hello, I was looking to store some values from our FactoryTalk Application using Datalog to a MariaDB. I see there is quite a bit of documentation...
103
