Connecting an Iwaki metering pump to a ControlLogix
The PDF you refer to is a Profibus interface that you connect with the pump.
So, if you want to control the pump by Profibus, you need this converter module. It is the T741 Profibus_converter module.
I am actually installing 3 of these right now in our water treatment system, works like a charm...
Greetings John.
I know I just can't find it online. I google T741 profibus converter and it give me converter but not the one in the PDF.
We already have the Prosoft comm card for Modbus. My goal is to connect 2 pumps to a Profibus converter to this card if its possible.
Thank for your help, appreciate your time
This is what i found in the pump manual and what i am using.
Iwaka part number 43122001
(I assume you wanted to know the Iwaka part not the controllogics interface)
I am using the pumps with an Innovation series controller with a Molex SST-profibus interface.
I have 2 PLCs. One is networked to our plant, and the other is networked to the first PLC via a 1756-EN2T. I could easily get the second PLC...
86
94
146
Hello, I was looking to store some values from our FactoryTalk Application using Datalog to a MariaDB. I see there is quite a bit of documentation...
157
I haven't encountered problems connecting to a PLC through VM Ware but I am with this particular machine. I'm running Windows 7 on a Windows 10...
262
