Connecting between Twincat to RT Toolbox 2
DT1
Apr 2017
Germany
I was trying to connect between Twincat 3 to RT Toolbox 2 via TCP/IP, I want to try using the sample program from beckhoff
Here is the link to the program :
http://download.beckhoff.com/downlo...6310-TcpIpServer/TcpIpServer_TCP_Sample02.zip
and by using the connecting program from RT TOOLBox 2, (sample Program.txt)
I was be able to get connection established status but unable to send data, it might be due to the RT Toolbox packet type has only CR and CR+LF.
Is there anyhow to change the packet type to other type like string or something other than those 2 inside the RT Toolbox 2?
I tried to do the same to connect and send data between Twincat and Cognex and it works because Cognex has String(NullChar) Packet type.
I am newbie in using the Twincat software. I have tried to connect between Beckhoff BX9000 and Twincat. But I was not successful. In the Twincat...
5,655
Hi I have two PLC AB compactlogix 1769-l16er-bb1b on the same location i need to read level sensor on the other PLC I know each one IP address...
1,300
Hello everyone! At present, I have 2 PLCs S7200 and 2 HMIs TP170. I want to connect them together. However, I don't know how do I do? May I have...
2,855
Hi, does anyone know of a way of communicating between a Omron CJ1M PLC and a Westermo GS-01 modem?
6,168
Good Day to all of you, this is my first post, i will try to explain as best as possible, english is not my natural language. I am performing an...
40
