Connecting CX Programmer to Omron CJ1m
kasonknight
Jun 2013
Houston
I've been having trouble getting online with a CJ1M-13. i am using a Keyspan USB-Serial cable and all of the com settings look fine. Everytime I try to use "auto online" feature the program seems to stall while it is searching- it stays on the screen shown in the image below for several minutes until I eventually have to force close. The network configuration tool within CX one has similar results when I try to scan serial ports - hangs on detecting until force close. I have tried with the #5 dip switch both on and off and get the same result. Any ideas? Thanks.
The Keyspan USB adapter usually works OK with a CJ1M IF you have the correct cable to connect to the PLC's serial port. The Omron serial port is not a standard pinout.
The normal setting for the serial port using toolbus is 9600,Even,7,2.
Thanks for the quick responses.
COM1 is mapped to the keyspan but I was in fact using a standard straight through serial cable (I am admittedly new to Omron PLCs).
I will give that cable pinout a try but I noticed the CJ series wasn't listed on the document. I have done some additional searching but have unfortunately found some variances in what others have said the pinout is : http://www.plctalk.net/qanda/archive/index.php/t-53115.html
Thanks again!
I am trying to connect to a CJ1M-CPU11. CX-Programmer 9.6 (Windows 10) is freezing while connecting via serial port. It gets to the "Searching"...
2,174
Dear all, I have been trying to connect an OMRON CJ2M CPU33 with the CX-Programmer 9.0. Every time I try, it fails to connect to the CPU. At the...
5,223
Dear All, I want to do connection from Cx-Programmer to CP1E-N60DR-A through CIF41 v2.0. I have tried connecting PLC direct to my computer or by...
1,541
Good Day to all of you, this is my first post, i will try to explain as best as possible, english is not my natural language. I am performing an...
42
87
