Connecting EATON HMi to EMERSON DX-480 motor control.
smart.Object
Aug 2008
Chicago, IL
Hello everybody...
I am very new to logical controllers but I was given a task to replace our broken t-21 data entry terminal, which is very old and very expensive, with EATON HMI04BU. All it needs to do is have a number panel, where operator inputs number of holes that gets sent to a drive in ASCII code. Please let me know if this even possible, and some of the first steps if it is. Right now I can't even get them to comunicate with each other through the serial cable....
Here is a manual for DX-480 motor control:
http://www.emersonct.com/download_usa/manuals/amplifiers/40022100.pdf
Thanks in advance.
GB
Did you ever get that hmi to work?
I too am placed in a similar situation were we don't want to replace the drives but have no alternative but to replace the input panel.
I have 2 PLCs. One is networked to our plant, and the other is networked to the first PLC via a 1756-EN2T. I could easily get the second PLC...
58
Good Day to all of you, this is my first post, i will try to explain as best as possible, english is not my natural language. I am performing an...
64
103
Hello, I was looking to store some values from our FactoryTalk Application using Datalog to a MariaDB. I see there is quite a bit of documentation...
123
I haven't encountered problems connecting to a PLC through VM Ware but I am with this particular machine. I'm running Windows 7 on a Windows 10...
253
