sriishivaram
In a bias cutter m/c a GE Fanuc 28 point PLC with Jayshree make encoder has been used.Now encoder has failed.Now I want to replace the encoder with Autonics make with same configuration.(1000 ppr/24v/3channel-A,B,Z)Will it be okay.Also in the PLC input common +24v is used.Encoder output A and B are used.(output from encoder is Totem pole output)Please let me know the outputpulse from encoder is +ve pulse or -ve pulse
